USA Roaming
  • 19 October 2022
  • 604 views
Good morning. We are going to the USA for a few days and need to be able to use my data whilst there. I know all ID Mobile plans use the Three network. Three do something called a “Go Roam” package which charges you £5 per day whilst in USA and it allows you to use all your allowances. Is this something I can get through ID Mobile or do I have to go to Three directly ??
Okay @djspenna, Three Uk and iD Mobile are completely independent companies.
The only connection is iD buy mobile network capacity from Three for their own virtual network.
iD have roaming partners in the USA, but don’t sell any roaming add-ons for customers.
Many places in the US no longer have a 2G or 3G network signal, and Huawei handsets aren’t welcome in US anymore. The iD roaming rates for the USA are:
Thanks @andewhite. Couple of people have suggested buying a SIM card when there and using that as would work out a lot cheaper !!
