can anyone tell me how to engage wifi calling as default, whenever I am on my home wifi? I use android.
thanks
thanks
Have you enabled Wi-Fi Calling on your handset?
You can check if your handset is compatible with WiFi calling with iD Mobile via the link below:
If you have WiFi enabled and your phone is compatible with WiFi calling with iD Mobile you can place the handset into Airplane mode and enable WiFi only and that should force the WiFi calling feature.
Let us know how you get on and if you require further information.
