With Data Roll Over, iD states that my unused data for last month will roll over to the next month.
Now will this only work for immediate prior months or work for all prior months
Essentially if I had 2 GB in Month 1, used 1GB, thus having 1GB rolled over on to the next month
My new data for the Month 2 would then be 3GB (I understand this, fairly simple)
Now if I used only 1GB again in Month 2, then would:
Scenario 1: 2GB (Month 1 + Month 2) be rolled over to Month 3.
or
Scenario 2: 1GB (Month 2 only) be rolled over to Month 3.
If Scenario 1, I would like to know what my stacked data limit is or if there are a limit to how many months worth of data can be rolled over.
If Scenario 2, I would like to know if my data would roll over if I hadn't touched it that month.
Hi @48-61-73-61-6e ,
Thanks for getting in touch! It would be Scenario 2 that comes into effect. We only allow the data of your original monthly allowance to roll over and not any previous rollovers.
So for example, if you're on a 2GB plan and you haven't touched any of your 2GB allowance at all, the full 2GB allowance will be available the next month on top of your 2GB standard allowance, giving you 4GB. If you again used no data at all, the next months allowance will just be 4GB and not 6GB.
I hope this helps.
I hope this helps.
Why iD
Mobile?
