Call charges to 0203 number | Join the discussion, ask questions, share advice.
  • 9 July 2020
  • 9 replies
  • 4780 views
I’m on a pay monthly plan - with plenty of minutes remaining, but have my ‘extra usage cap’ set at £0.
I’ve just tried calling an 0203 number, but i get a recorded message saying that my account has insufficient balance to make this call - suggesting that an 0203 number isn’t included in the call plan - which surely isn’t correct?
Best answer by Mohammed 17 July 2020, 12:45
Hi there @kc9403
If the number is simply a regular ol’ personal landline number then their shouldn’t be any issues.
Is the number in question a hospital bedside number -or- one associated with a business?  It would only be blocked in the way you experienced IF it was chargeable.
Hi @Kevin
Thanks for your reply - it’s a number i don’t recognise - so I have no idea - the first 7 digits are 020 3435 xxxx - is there any way to tell?
Surely a user can’t be expected to know whether a number is chargeable or not, when it appears to be a regular London 020 3 number?
Hello @kc9403,
02 numbers are inclusive in your allowances like 01 and 03.
It’s possible that the number is disguised to look like a standard 02 number but is actually an international one.
Have you tried Googling the number to see what company it relates to?
Have you definitely got inclusive minutes remaining?
Hi @Mohammed,
Thanks for your suggestions - Not sure how the number could be disguised, it’s starts 020, and is followed by exactly 8 digits, as you would expect for a London number.  I’ve even tried dialing it manually, rather than calling the entry in the missed calls - but get the same result.
Yes, i’ve tried googling it, but nothing of any use is found.
Yes, i’ve got inclusive minutes - as i can make other calls. As an experiment, i’ve just googled a random pizza place with a phone number starting ‘0203’ - and that rings just fine!
It might be worth blocking the number @kc9403
If it’s not a call you’re expecting, then it could potentially be part of some scam.
Usually googling a number would be a good source of information, though if it’s a new thing then there might not be information online yet.
@Kevin
Yes, i’m sure you are quite right that it probably is a scam - however it just raised an interesting question that apparently you can’t tell if a number is included in your inclusive calls or not - ie you can ring a seemingly included 020 number, but you may be charged for it, at some unknown rate.   I only discovered that this was a chargeable call because I have my usage cap set at £0, so the call was refused.
Hello @kc9403,
You can usually make out these numbers but can be very deceptive indeed.
For example, non-standard numbers https://www.idmobile.co.uk/nonstandard07numbers which are chargeable but look like normal UK numbers.
Standard UK mobile numbers, 01, 02, 03 & 0800 numbers are included in your plan.
Hi @Mohammed
Well, this is most definitely a 02 number (followed by 9 other digits) - but it’s certainly not included in my plan.  So there must be a list of exceptions for 02 numbers too.
Badge +8
Hi @kc9403 , we don’t have a list of scam numbers, but we advise blocking them once they're brought to your attention.
Cheers,
Will
