Problem sending texts
  • 30 June 2022
  • 568 views
I am very happy to have switched to your network , there are only two things that concern me
The first is: I have a problem with sending messages. I send a text message and I get a notification that the message could not be sent, and despite the notification some messages are sent anyway, but it is annoying because I do not know which messages have been sent and which not
The other thing is that I wanted to leave my old number, I transferred it to you and it is still my main number, but when I send a message or make a call it is the number you assigned to me (it doesn't work every time either), could you please check this?
I would be very grateful
Best answer by Rory 1 July 2022, 14:37
What handset are you using?
Userlevel 5
Hi @Magdalenaroman2210, if you’re using an iPhone, could you please try this for me?
If you’re using an Android device, please try going into the Message app, tap settings and find Chat Features. Turn it off, then back on.
Rory
It’s works
Thank you Rory
Userlevel 5
Glad to hear that @Magdalenaroman2210 :)
Rory
