problem with messaging and changing my number in settings
  • 12 July 2022
  • 326 views
My messages say failed to send but sometimes they actually have sent , I’ve looked through the help section and I can’t get my ported o2 number to save in my settings it just reverts back to your original id mobile number ?
Best answer by andewhite 12 July 2022, 22:29
Have you tried a network reset?
Your phone’s user guide should tell you how to perform a network reset, which often fixes the issue you’ve described.
Anyway, good luck.
Userlevel 5
Hi @Jenny Evans, if you’re using an iPhone, can you please try the following?
If you are having issues with the above please retry with flight mode enabled and/or the SIM card removed.
Rory
