Hi will still get the above even if i not make or take call on my number
Can I get answer on email address below as the one given is not access able at present
[REMOVED PERSONAL EMAIL]
Many thanks
Sanjay
Page 1 / 1
Hello @Aayush10 ,
Can you clarify what you mean by this?
Are you currently Roaming and want to know how to avoid being charged?
Just turn off Roaming in the handset settings and switch this off in your iD account.
Keep your handset in Areoplane mode and you should not be able to connect to any networks this way to avoid being charged if you're roaming in a non-inclusive country.
Reply.
