Volte and WiFi calling on OnePlus 3t
  • 11 September 2018
  • 1129 views
Hello. I currently have a OnePlus 3t running on a BT Mobile SIM card. I have volte and WiFi calling working as BT allow any compatible handset to access the services even if not bought through them.
Do iD mobile allow this or does it only work on handsets bought from them like Three do?
Best answer by Phil 14 September 2018, 13:53
Userlevel 2
Hi Rover, WiFi and 4G calling will only work on compatible handsets and the OnePlus is not covered unfortunately.
We are expanding the list of handsets supported, however, this will most likely be constrained to handsets sold by us.
-Phil
Hi I posted this on another thread and I'm just going through them letting people know about this for OnePlus
I've got the 1+6t and I think I've found a work around for the wifi calling option.
Dial *#800# > oneplus Logkit > Function Switch > Then tick VoLTE switch and VoWifi Switch > Reboot.
It's worked happily on my 3, 3t, 5t and 6t. I will test it on the 6 over Christmas
This should bring the wifi calling options online under the SIM settings. Hope this helps
