For a few weeks now, I am rarely able to make calls, when calling someone it says calling on the phone but there’s no ring tone and then after a while it says call failed, also people are for the most part not able to ring me as it either doesn’t ring my phone or goes straight to voicemail.
Okay
No
Anyone????
Hey there
We’re sorry to hear this. Please note, on Community, our response times will vary, so if you’d like an instant response, we’d recommend contacting via live-chat:
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please let us know, and we can investigate further.
Kind regards,
Won’t let me ring out keeps saying call failed and I can’t speak to 3 about if the network is down
Hey there
