What is ID Mobile’s APN
View originalHey
You can find the APN settings in more detail on this article:
Please note, you should not need to update your APN settings on an iPhone - the settings should automatically update.
Let us know if you need any further assistance.
Nikhil
I’m using an LTE-CPE ROUTER not aphone
Unfortunately, the only devices iD Mobile specifically support on their network are mobile phones, and even then it’s best to ensure you’ve got an approved handset.
Good luck
