APN setting
  • 25 November 2022
  • 791 views
What is ID Mobile’s APN
Best answer by andewhite 25 November 2022, 17:55
It is “id” - in lowercase.
Badge +3
Hey @dvdevns,
You can find the APN settings in more detail on this article:
Please note, you should not need to update your APN settings on an iPhone - the settings should automatically update.
Let us know if you need any further assistance.
Nikhil
I’m using an LTE-CPE ROUTER not aphone
Unfortunately, the only devices iD Mobile specifically support on their network are mobile phones, and even then it’s best to ensure you’ve got an approved handset.
Good luck @dvdevns.
Hey @dvdevns,
As @andewhite mentioned, this isn’t supported but you can try editing the apn settings via the router settings page as it may still work.
We don’t provide support on this though.
