I am going on a cruise and that will be expensive, but if needed what is the best way to get roaming as I have unlimited for the 50 countries but not in the far east. Should I just set a cap on my account?
View originalI am going on a cruise and that will be expensive, but if needed what is the best way to get roaming as I have unlimited for the 50 countries but not in the far east. Should I just set a cap on my account?
View originalPerhaps buy a data only eSIM, if your handset supports these, which covers the countries you’re visiting in SE Asia.Â
Companies like Airalo, BreatheSIM, Flexiroam, GoMoWorld, Holafly, Soracom Mobile, UPeSIM, etcetera sell data only eSIM plans for travellers. Maybe consider a regional data only eSIM plan for your cruise.
Try and avoid using the mobile network onboard the cruise linerÂ
