I have a Pixel 6a, latest Android 13 version, all updates are up-to-date.
I am trying to use the call forwarding option but it throws error. Please see image.
Regards
Laszlo
Best answer by Mohammed
View originalHi,
Regards
Laszlo
View originalI’d guess iD Mobile don’t support this feature.
If the mobile network operator (iD Mobile) do support the call forwarding feature, then maybe you need a replacement SIM card.
Good luck
Thank you for your help.
I was not aware a different SIM card is required to have the call forwarding enabled.
I think this feature is enabled at ID Mobile as I can find quite a few threads where people are asking how to disable the option.
Kind regards
Laszlo
Kind regards
Laszlo
Okay
Anyway, good luck
Thank you
Thank you
Hey
The last time we raised this issue, we were told that Call Forwarding was not supported.
Thank you for your answer.
