Call forwarding is not working
  • 3 October 2022
  • 6 replies
  • 390 views
I have a Pixel 6a, latest Android 13 version, all updates are up-to-date.
I am trying to use the call forwarding option but it throws error. Please see image.
Regards
Laszlo
Best answer by Mohammed 5 October 2022, 17:10
I’d guess iD Mobile don’t support this feature.
If the mobile network operator (iD Mobile) do support the call forwarding feature, then maybe you need a replacement SIM card.
Good luck @Laszlo
@andewhite
Thank you for your help.
I was not aware a different SIM card is required to have the call forwarding enabled.
I think this feature is enabled at ID Mobile as I can find quite a few threads where people are asking how to disable the option.
Kind regards
Laszlo
@andewhite
Kind regards
Laszlo
Okay @Laszlo, I think quite a few of those threads were posted by people who ported over to iD from another network operator, where call forwarding was supported - EE for example.
Anyway, good luck @Laszlo.
Thank you
Thank you
Hey @Laszlo,
The last time we raised this issue, we were told that Call Forwarding was not supported.
@Mohammed
Thank you for your answer.
