Data not working, reset settings, tried aeroplane mode, restarted phone, manually input settings. no solution.
  • 26 January 2022
  • 409 views
Data not working, reset settings, tried aeroplane mode, restarted phone, manually input settings. no solution. 2 days it's been doing this now have an exclamation mark beside my signal bars. WiFi is no problem and still receiving tects and calls
Best answer by andewhite 26 January 2022, 21:48
Hello @Srollsrus,
Anyway, good luck.
Hello @Srollsrus,
Anyway, good luck.
Found the culprit. 👍
Not ideal, but at least you know there’s a network problem.
