data roaming
  • 5 February 2024
  • 292 views
Hello there,
I wanted to ask how much would i get charged if i were to use data roaming whilst in Saudi Arabia for 10 days?
Best answer by andewhite 6 February 2024, 12:32
Userlevel 3
Badge
Details can be found on this page https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges
How much roaming mobile data are you planning to use in Saudi, @Yasin Quddus
The iD Mobile charge for roaming mobile data in Saudi Arabia is £3.60/MB.
So if its £3.60 per MB, then how long does it take to use up a single MB ?
How long, will depend on the apps running, and what you’re doing with mobile data, @Yasin Quddus. How much data do you use each month in the UK?
Hi @Yasin Quddus,
Using an iD Mobile SIM for roaming in Saudi Arabia may end up very expensive.
It may be worth using a local SIM whilst there or sticking to Wi-Fi options such as Whatsapp.
