Data is not working in France. I can make phone calls and send text messages but I’m unable to use data. Can anyone advise on how to fix this issue?
Did you find a solution as have the same problem
Whilst in France please can you try and connect to the following networks BYTEL/BOUYGTEL, Free Mobile and Orange.
Can you also confirm which make and model handset you are using?
It may also be worth double checking that roaming is enabled on the handset and the iD Mobile app.
