DATA ROAMING NOT WORKING IN FRANCE
  • 23 March 2024
  • 143 views
Data is not working in France. I can make phone calls and send text messages but I’m unable to use data. Can anyone advise on how to fix this issue?
Did you find a solution as have the same problem
Hi @Steelmen91 @Benble,
Whilst in France please can you try and connect to the following networks BYTEL/BOUYGTEL, Free Mobile and Orange.
Can you also confirm which make and model handset you are using?
It may also be worth double checking that roaming is enabled on the handset and the iD Mobile app.
@Kash I have an IPhone, unfortunately ID were unable to help, it appears ID have not enabled IPhone users to be able to change the APN and looking at others with the same problem the only solution is to leave ID to be able to use it in France
Hi @Benble
I’d recommend trying the following;
