I can’t send IMessage.. Please Help.!!
  • 24 April 2023
  • 22 views
Hi @Gemdepper
What seems to be the issue with iMessage?
Did you mean to send the above picture?
Please try the following;
If you are having issues with the above please retry with flight mode enabled and/or the SIM card removed.
