Having switched to ID mobile my old number is still not showing up when dialling phone numbers or messaging, i have already sorted out the PAC code
View originalHaving switched to ID mobile my old number is still not showing up when dialling phone numbers or messaging, i have already sorted out the PAC code
View originalTry:
Tried both options and it is still not recognising the old number I'm afraid.
It is a new iPhone with email address
Okay
Anyone with Internet access can read posts in this forum, and there are scammers out there looking for email addresses, mobile numbers, et cetera.
I recommend you edit your post and remove the email address.
Anyway, when you sign-in at https://appleid.apple.com with your Apple ID - and look at your Devices, do you see the correct mobile number against your iPhone device?
Thanks for the heads up on that!
I have just checked and the correct mobile number is showing on the new device and I have cancelled my old phone from there as well.
Please could you try the following?
If you are having issues with the above please retry with flight mode enabled and/or the SIM card removed.
