Hi I'm getting important calls from NHS but my phone isn't ringing, just vibrating once and there is no answer button to answer the calls
Best answer by WelshPaul
View originalHi I'm getting important calls from NHS but my phone isn't ringing, just vibrating once and there is no answer button to answer the calls
View originalSounds like you may have added the number to your block list. What phone do you have?
Can you check that the number isn’t blocked.
Is the software up to date? Do you get issues with any other numbers?
It may be worth testing it in another handset as it may be a handset issue.
My phone did a software update at the beginning of the week and unfortunately I don't have another handset I can try my sim in
