id mobile pin
  • 16 September 2021
  • 234 views
I keep my idmobile phone in Thailand, I am in the UK, I want to upgrade, but it does not recognise my pin, last two digits of bank for direct debit and last two digits of mobile number, a and to set up the id mobile app, it sends a code to my phone, which is in Thailand.
Best answer by Siân 16 September 2021, 12:48
Userlevel 3
Badge +1
Hello @Gary Cox welcome to the community.
Just so I am correct in understanding, you are wanting to upgrade with iD and you are sent a PIN to your phone to verify the upgrade, but you have left your phone in Thailand so cannot recieve the text, is that right?
Yes that is correct
Badge +8
Hi @Gary Cox,
We’ll need to send you out a new SIM card so you can activate that on your existing number, place it in a handset, and get your code. We’ll shortly send you a Private Message to your Community account, so we can discuss your issue further.
Will
