How much does it cost to receive calls in Australia?
View originalHow much does it cost to receive calls in Australia?
Just a note, if you are going to enable roaming in Australia, it will be best to keep Mobile data OFF.
If this is on, your device will connect to data and use background data to retrieve push notifications etc and this can quickly add-up.
