My Iphone 14 pro shows 4g but will not connect to internet
Thanks for your post.
This may be down to a few things.
Is mobile data enabled on your handset?
You can check the coverage and network status at the link below:
If the coverage is good and no work is being carried out, please test the SIM in another handset.
Â
How many handsets do you think I have. 5G phone, only possible 4G, not getting that either. No 3G.
Poor show
Â
Poor show
Â
Perhaps the 3G has been switched off in your location,
Three UK (the iD network partner) are turning off 3G by the end of 2024 - already off in the following areas:
Â
