Has anyone got some advice for me regarding LTE camera’s? I am thinking of buying a Reolink Go Plus camera that needs a sim card. I live in the countryside with only BT hotspot wifi which means I have no router box or reliable mains wifi so decided to use an LTE as will be walking over fields away from the cottage where there is 4G but doubt if wifi would work.
Any help any advice most welcome
Regards
Rod Smith
LTE Security Camera sim card
Hey
Our SIM cards are only approved to use in handsets but I have seen others use it in routers and car systems.
Just make sure that the device has the correct APN settings as this can impact access to services and by default the APNs may pick up as the Three UK ones.
You can find the APNs here:
Name | iD |
APN | id |
Username | <leave blank> |
Password | <leave blank> |
MMSC | http://mms.um.idmobile.co.uk:10021/mmsc |
MMS Proxy | mms.idmobile.co.uk |
MMS APN Username | <leave blank> |
MMS APN Password | <leave blank> |
MMS Port | 8799 |
