I’ve just upgraded my id contract and requested to keep my sim. I’ve put my sim in my new phone and can get Wi-Fi but no mobile data. I’ve tried all the recommended fixes but nothing is working. I’ve tried the chat bot and asked to speak to an adviser but have been told they are too busy. how do I get help from ID for this issue asap?
I have an iPhone 11.
It might seem obvious, but is mobile data turned ON on your iPhone 11
Turn mobile data on/off from Settings > Mobile Data.
You can contact iD customer support (privately) using Facebook Messenger, or X (Twitter) DM
Thanks for your help, this was the first thing I tried. I think they’ve accidentally deactivated my current sim (i asked to keep my current one) and not sent me a new one. I’ll try contacting them as you suggest.
If calls and texts work, doesn’t sound like your ‘old’ SIM has been deactivated.
Anyway, you can activate the ‘new’ SIM from your iD account online (or iD app)
Thanks but calls and texts aren’t working. Only what’s app when I connect to Wi-Fi. ID haven’t sent me a new SIM but I got a message to tell me my new sim was being activated and my current one isn’t working anymore so I’m feeling a bit stuck. I’ll try contact customer services again
Sounds like iD might’ve made a mistake
If your existing SIM has been deactivated, you’ll probably need a replacement SIM card.
You can pick-up a free replacement iD SIM card from any Currys store, otherwise try the iD online customer support.
Thanks so much for your help, much appreciated.
