Hi All
Trying to use my sim in my netgear but cant find APN settings to use anywhere.
Can someone help
my EE sim worked fine
Best answer by WelshPaul
View originalHi All
Can someone help
View originalHey
There is a network issue affecting THREE, SMARTY and iD Mobile so data may not work right now.
Thought that may be the issue as it worked when I tried the set up in house yesterday but not today in the motorhome on the drive. Typical, my head was about to explode. Thanks for your help 😀
DATA isn’t working on my son’s phone using SMARTY. He has been getting a PDP Authentication error most of the day but it works on mine. His sim has been unregistering and registering on and off most of the day too! iD Mobile and SMARTY have announced that they are experiencing network issues but THREE have not. No idea if it’s only MVNO’s that are having issues or THREE too. Save your sanity and test again tomorrow. 👍
Just checking if you can use the data on the NetGear device?
If not, please let us know and we can help you out.
Hi Kash. No i cant use it in my netgear. Put in my iphone just now and all ok.
I need settings to put in netgear APN settings page
WAIT!!!!
Its now working :)
yee haa
Thanks for checking
