Network Issue
  • 1 December 2023
  • 22 views
Subscription base issue is not a network issue per sa!
If you ported from another network, try:
Select your previous network by removing the automatic network selection in mobile settings.
Hit flight mode.
wait 30 seconds or so.
then toggle out of flight mode
then go back to network selection and select ID
it might just connect you (worked for mine and the mrs!).
Hi @Billy2p,
Thanks for taking the time to share that information.
We’ll be sure to keep that as a troubleshooting option.
