This has been asked before, but the thread stopped months ago. I bought a new phone with 5G. A Realme GT2 pro. It’s a phone that’s been around for a while. No option for 5G on ID mobile as far as I can see. other networks seem to support this phone including giffgaff etc. Why are ID mobile so far behind.?
Hey
Not all devices are tested and supported for 5G.
What if I don’t have a 5G enabled phone?
Unfortunately, 5G requires a 5G enabled phone for you access it. But don’t worry! We’re working with our network provider to ensure our 4G services are providing the best coverage possible. And don’t forget we already offer Wi-Fi Calling, letting you make calls from your phone over Wi-Fi if you don’t have great reception indoors.
You can find the list of approved handset here:
Maybe try SMARTY or Giffgaff instead in case i have more joy there.
Mark
Other networks will support other devices, it’s possible and likely that they would support devices we don’t, and visa versa.
no you need to sort something in the automatic discovery of the networks for some phones like realme ,oppo , vivo , because the software is very similar , like i said even on the realme i could get the 5g working but only with forcing it with third party apps to connect on 5g network because ID automatically couldnt tell the phone 5g is available
now i bought ZTE nubia z50 and it catches 5g fine which is nowhere to be seen on your site of supported devices ...
you have probably seen my thread
only way to get the 5g is going to the engineering menu (many apps can access it) and select NR which is 5g but after restart it will switch back to 4g so you have to keep doing it after every restart
i tried few other operators and all were automatically detecting the 5g (havent tried three sim though) maybe the fault is on three
Hello
Not all devices are approved but some non-approved devices work fine also.
It’s just not stable so an update could stop it working.
We don’t test all devices available on the market as there’s just too many so we mainly focus on handsets for contracts which we sell.
