Family and work is unable to call my number . No idea how long this has been going on for. My number was ported however has been working before.
Best answer by adam1295
View originalFamily and work is unable to call my number . No idea how long this has been going on for. My number was ported however has been working before.
View originalHey
Bad actors, scammers, and spammers do visit this forum looking for this type of information.
Hey
Don't know how to even remove the post. Not the easiest to use website
Okay
Okay
Unfortunately not, I have reported it however
The edit option should be there for each post you make
Unfortunately not. Can you make a new topic and report back if you are also unable to edit
If I worked for iD Mobile, I’m sure I could
FYI, I’m able to edit the posts I make to this forum - I’ve never had a problem editing my own posts.
Seems to just be this post as I created a new topic and can edit that. possibly has something to do with a user commenting on it stops the editing?
