I have used OS maps on my old phone switched to a Moto 32 and it does not function properly.
I have downloaded the map of the area I will be walking in, so that I can still record my route even if I loose phone signal.
I keep having the app loose signal and draw straight lines on the map often to point miles away from where I am. The GPS and Google maps work but OS maps doesn't.
Can anyone suggest a fix.  Â
Best answer by Mohammed
