Phone call connection
  • 3 October 2022
  • 161 views
When making calls... Either I can't hear other person or they can't hear me. Its a very broken line and you hear half a sentence. I don't have another phone to try sim in.
This something that's had been ongoing for ages
Best answer by WelshPaul 3 October 2022, 18:48
Maybe your phone is faulty? Try replacing the SIM card and see if that makes a difference.
Thank you. I'll request a new sim card.
Hey @cspinner66,
Let us know if you still need help with getting a replacement SIM card.
Hi  Mohammed,
I've only made 2 calls and both was OK. I had 2 bars of network signal and WiFi was 3 bars
Not sure why?
Caroline
Hi @cspinner66
Is this on a replacement SIM card? If you’re still having issues with your calls/signal please let us know.
Hi Tom,
No replacement sim.  Was asked by Mohammed to record all calls, service, day, time. He thinks it's probably WiFi or services not good at time of call.
I don't seem to make that many calls, but the ones I do, some are OK.
Kind regards
Caroline
Hi @cspinner66
If you’re using WiFi calling it could be worth turning this off and retesting services then.
Should this not change anything please contact us about a replacement SIM.
