Pixel 7 Pro wifi network issues
  • 25 July 2023
  • 59 views
i have just received a Pixel 7 Pro.
The device first sees WiFi networks, connects then disconnects and never reconnects. It then doesn't show the available networks. I have tried resetting the network settings and a factory reset and still the same issue.
Do I have a faulty device?
This article might help you decide on the next steps @JohnnyJungle.
I actually managed to get it working, I had to do a system update over mobile data nearly 500MB lucky I have unlimited data. After the update it connected to wifi and hasn't disconnected.
Sounds like there might have been an issue with the Android version running on your Pixel device @JohnnyJungle - at least it works now.
Hi @JohnnyJungle
Glad to hear that a software update fixed this, let us know if you need assistance with anything else.
