calls to this number prohibited when calling numbers even from my contacts that I have called many times before. This has only happened today following an update
You’d be able try resetting your network settings to reboot the connection. Alternatively, you’ll be able to test the SIM in another phone to see if you’re still experiencing the same issue.
-Lauren
