Replacement Phone
  • 22 April 2024
  • 35 views
My phone is damaged and will be replaced by insurance, do I need to tell iD Mobile any details of my replacement phone when I receive it?
Best answer by andewhite 22 April 2024, 17:09
If you owned the phone that’s been replaced, probably not, @Iain Adam.
Are you within the minimum-term of a 24-month handset contract, @Iain Adam?
Yes, within the contract period, thanks.
Okay @Iain Adam, technically you don’t actually own the phone until your minimum-term ends, so iD Mobile might need to know.
Perhaps, worth checking your iD contract terms & conditions.
