I am going to Kos on holiday. It is often recognised incorrectly as being in Turkey on my phone and roaming charges would be incorrectly applied. Any advice on how to avoid this. Thanks.
View originalI am going to Kos on holiday. It is often recognised incorrectly as being in Turkey on my phone and roaming charges would be incorrectly applied. Any advice on how to avoid this. Thanks.
View originalThe iD roaming partners in Greece are Cosmote and Wind Hellas.
You could try and manually select the network for roaming - hopefully that works, and avoids any unexpected charges.
