Having switched to id from giffgaf. My old number was ported successfully however texting is showing new number still on caller ID. How can this happen on single sim ?
If you are having issues with step 4 please reset network settings and try again. Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
