My iphone broke. If I get a replacement, can I simply swap the SIM card over? Do I have to do anything or wait for it to register to the new device?
If the existing iD SIM card fits in the replacement handset, then services should work okay.
You can normally use your iD SIM card in whatever mobile phone you choose
For list of ‘approved handsets’, see https://www.idmobile.co.uk/help-and-advice/approved-handsets.
Ok, that sounds easy enough.
Thank you.
