Using an eSim
  • 31 May 2023
  • 3992 views
My current plan is with ID mobile and I am travelling to the US next week.
I plan on using an eSim whilst i am there, however i have read online that ID mobile do not support eSims.
Does this just mean that i cannot buy an eSim from ID mobile?
If i buy an eSim via another provider will it work?
My iPhone is unlocked.
Thanks in advance
Best answer by WelshPaul 31 May 2023, 14:49
As mentioned many times on here iD Mobile do not offer eSIM. You can however use a third party eSIM as a second line on your iPhone.
Hi @Stmcljen01
As @WelshPaul suggests unfortunately we don’t support eSIMs and don’t currently have any plans to, sorry about this.
You may be able to purchase an eSIM from another provider and use it with your device should it be unlocked, however this would be a different phone number to the one with iD Mobile.
