wrong phone number on device info Iphone
  • 9 March 2024
  • 43 views
I transferred my number from EE but was given a temporary number when I set my new phone up.
For some reason the temporary number is stored against the phone in device info meaning I get an irritating “message failed to send” message for every text sent although they do go through. I can’t simply just edit the number and it is driving me crazy!
Has anyone found a fix for this?
Perform a ‘Network Reset’ @Graham Cronshaw. How you do that depends on what device your using.
Hi @Graham Cronshaw,
As @WelshPaul mentioned please try a network reset, if that doesn’t fix the issue please let us know the handset make and mode so that we can guide you through other steps.
