Zte Lte mifi apn settings for Europe
  • 23 February 2024
  • 35 views
I hava an unlimited id  sim currently working in my ZTE LTE mifi unit, at the moment it is working great, although it thinks it's a 3 unit in the apn settings, will I have to change the settings to work in Europe. It is set to roaming. Also will it still be unlimited in Europe for 90 days like it was last year.
The APN value will need to be “id” (lowercase), for roaming mobile data to work in an inclusive roaming destination, @Ian Worthington
Hi @Ian Worthington
If you do have issues roaming, it may be worth trying the above from @andewhite, however it’s worth noting that while the SIM card may work in this device, it may not be officially supported, so features and ability to use the SIM in this device may differ.
