Best answer by Mohammed
That would explain the issue here.
The Three UK APN setting works fine in the UK but when you're Roaming, you'll need to use the iD Mobile APN Settings found here: https://www.idmobile.co.uk/help-and-advice/get-your-settings
I've attached a screenshot in-case you are unable to access the website to locate this.
