PAC code
  • June 2, 2021
  • 42 views
Kociczka19896
Hi if anyone can give my my Pac code. I took stac just to see if i can get any. If i was getting PAC i couldnt took it but i dont have problem to get the STSC intead. Can i have my PAC code pls?
Mohammed H
  • 7962 replies
  • June 2, 2021
Hello @Kociczka19896,
Sorry I’m having a little trouble understanding your above message.
Do you mean that you wanted a PAC code but accidentally took a STAC code and now you need to cancel this before you can get a PAC code?
A PAC code is used to keep your number
A STAC code is used if you are not.
