Data Roaming in Spain
  • 18 September 2022
  • 784 views
Wondered if anyone could advise.
I'm currently in Spain, originally UK based,and my data roaming isn't working. Calls and texts are fine.
Please find attached screenshots of my settings.
Any help would be greatly appreciated as I do need data for work. I'm currently having to rely on the hotel WiFi which is less than ideal.
Best answer by Mohammed 28 September 2022, 14:59
Sorted. Something to do with the APN settings
Hello @Kane001,
I was just going to say from looking at the photos, the APN settings seem to be set to 3UK.
It works fine in the UK as we use Three UK’s network for coverage,but when roaming, you need to set it to the iD ones for it to work.
Glad you got it sorted.
You can mark your answer as the best answer so people know for the future.
