Hi I'm currently in the US and I recently changed my cap to £50 and using mobile data still isn't working. I've tried doing the APN to change network but it isnt working and I've reset the phone multiple times. I've turned on roaming on both the phone settings and the ID mobile app but its still not working. Any fix?
Roaming not working
Hey
Sorry to hear you had issues. Did you find a resolution? Our Roaming Charge is £0.30 a MB of data, so you wouldn’t be able to use your phone much before hitting a £50 cap.
Hi I wasn't able to find a solution as I still have the same problem. I'm not able to use WhatsApp or anything without WiFi currently
Yeah, with an eSIM capable handset, a data-only eSIM with a US travel plan is a better option than iD Mobile rates for roaming data in the US.
I’ve used a Soracom Mobile eSIM in the US, which worked well for me.
download the easySIM and AILALO apps…. with easySIM you can get 10GB US Roaming for £16, other options available too. Not tried them yet myself, that will be end of next month.
