uk landline calls when roaming
  • 7 August 2023
  • 288 views
Can’t make UK landline calls from Europe all my roaming is turned on and spending cap is on and I have both extra minutes too , nothing works and I really need to make landline UK phone call . Thank you .
Best answer by Mohammed 7 August 2023, 12:49
Userlevel 4
Badge
Are you replacing the “0” at start of number with “+44”?
yes , i have even bought more minutes to add on but it doesn’t work
Is this all UK landlines, some UK landlines, or just one UK landline number @matalia.
What numbers aren’t working?
Hey @matalia,
You can’t call 0800 or 0808 numbers when roaming as these do not work.
Assuming it’s a standard landline like 01, 02 or 03, then it should work.
You can try switching to a different network as I had a customer with a similar issue today and there was a problem impacting calls on the network they were on and was fixed by switching networks.
What country are you in?
