Hello. I will be travelling to the United Arab Emirates with my ID mobile phone. Prior to leaving the UK, I want to unconditionally divert/forward all calls to my spouse at our UK home landline number (which will remain in the UK).
However, I want to keep the SIM active for incoming SMS (bank OTP codes, emergency use, etc) while in roaming at UAE.
If I set up unconditional forwarding/divert to a UK number, will those minutes be taken from my UK allowances, or will I incur roaming charges if my SIM is on abroad when the call is diverted? (£6.00 /min roaming charges for UAE).
Many thanks.
Best answer by Mohammed
