I will be in Morocco for ten days later this month. Can I use an e-Sim on my iPhone when in Morocco - does ID Mobile permit this?
Best answer by Kash
View originalI will be in Morocco for ten days later this month. Can I use an e-Sim on my iPhone when in Morocco - does ID Mobile permit this?
Best answer by Kash
View originalI don’t think iD will prevent you from using an eSIM in your iPhone
Currently iD Mobile don’t support eSIM technology on their network, so I’m guessing you’ll be using an eSIM from another mobile operator.
Good luck
Hey
As
Â
Thanks, Mohammed. Could you please clarify one point - when you say that ID Mobile does not support eSims, does that prevent me from using another company’s eSims with my iPhone? Or if I wanted to use a local Moroccan Sim, would that be possible?
