Using my phone in Morocco
  • 13 December 2022
  • 2352 views
I will be in Morocco for ten days later this month. Can I use an e-Sim on my iPhone when in Morocco - does ID Mobile permit this?
Best answer by Kash 18 December 2022, 14:30
I don’t think iD will prevent you from using an eSIM in your iPhone @Argus.
Currently iD Mobile don’t support eSIM technology on their network, so I’m guessing you’ll be using an eSIM from another mobile operator.
Good luck @Argus.
Hey @Argus,
As @andewhite advised, we don’t support eSims and Roaming is not inclusive in Morocco so any usage would be chargeable at the roaming rates: https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges
Thanks, Mohammed. Could you please clarify one point - when you say that ID Mobile does not support eSims, does that prevent me from using another company’s eSims with my iPhone? Or if I wanted to use a local Moroccan Sim, would that be possible?
@Argus,
You can still use a different eSIM or a local SIM, however eSIM isn’t something that we offer at the moment.
I hope that helps.
