Using 'phone in South America
  • 2 August 2023
  • 6 replies
  • 698 views
Userlevel 2
Hi - I am going to Peru later this year and would like to find out about roaming charges if I want to make a call, send a Whatsapp message or a text.  Is it likely to be very expensive?
Best answer by andewhite 2 August 2023, 15:55
https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges - select Peru from the list to view charges
Roaming Pay monthly Pay-as-you-go
Calls to UK* £6.00 £6.00
Calls to Peru* £6.00 £6.00
Calls received* £2.40 £2.40
Texts to Peru** £1.20 £1.20
Texts to UK** £1.20 £1.20
Picture message (MMS) sent** £0.60 £0.60
Internet and Data (per MB)*** £15.00 £15.00
* Price per minute
** Please note: MMS charges vary. For further information, refer to Terms & Conditions.
Looks like roaming in PERU using iD Mobile is expensive… might be worth looking at using an eSIM instead, if your handset supports these @AHutton54.
Hey @AHutton54 It’s not inclusive of roaming so may well be worth getting a local or eSIM when abroad.
Just be sure to cap your plan at £0.00 and configure the eSIM correctly.
Userlevel 2
Hi Mohammed - many thanks for taking the trouble to reply. I'd been thinking about a local SIM. Thanks to everyone for your help and suggestions.
Hi @AHutton54,
Glad that we could help.
Userlevel 2
Thanks Kash
